I'm gassy.
69charger
so, with the current engine build i'm going with, the compression ratio is supposed to be a whisker under 10:1 and this isnt a big deal because I'm not going to drive it daily but it got me wondering on what I should do as far as my fuel is concerned.
I figured that I could just get the premium grade at the gas station then dump in some additive, but i read that octane boosters can only raise the level so much especially when you initially start out with a higher octane....so, what's a guy to do?
better yet, what do you guys do?
besides go to a station that pumps out 100+ octane leaded gas and buying race fuel what else could you do?
maybe mix half racefuel and half premium pump?
You should be fine with 91-93 gas with 10-1. I have been running a 10-1 moter on 91 with no problem at all in 90+ degree wether.
