WymanV
..you said "member"...
Hey all,
The long term project is finally coming together and as I turn to the brakes I find myself missing a couple of crucial parts. Notably-
Both front stand-off brackets. The part that the brake hose mounts to on the back of the wheel. All I can find is a broken piece of one. These would be for the 10" drums. They are "sided" and I need both sides, it seems. The part is circled in the pic I shamelessly downloaded in green (square C):
I could also use the rod that connects the manual brake master cylinder to the brake pedal. I could opt for a generic aftermarket one but I would prefer OEM if I can find one. Also looks like I need the junction block the brake lines connect to on the rear axle (8 3/4").
Thanks
Ken
Thanks
Ken
