for those of you that have done a mini tube on your 70-71 dart swingers and shortened your 8 3/4 housing and moved your leaf springs to the frame what is the distance from center perch to center perch on your housing? would i be ok with setting my pinion angle at 5-7 degrees with Calvert split mono leafs -1'' any info would be very much appreciated Thanks in advance Dave
