Budgetmoparman
Trying to get my 340 timed today and something is crazy. I had the initial timing at 50* before it kicked back on the starter. It starts great and idles great around 43-45*. I checked the timing marks and verified that 0 is TDC. I used a dial back light and a cheaper non dial back light and get the same thing. 70 340, comp XE268 cam, not sure of compression- basically stock build with cast heads, msd 6al box, factory distributor- tried 2 different sets of springs, taylor 8mm wires, autolite 65 plugs, balancer is aftermarket street/strip- can't remember the brand. What the heck is going on with this thing? Vacuum advance is blocked off.
