Insight on cam numbers
Firstblood
NW Pennsylvania
I have some notes from a previous owner on the cam in my 1965 Dart GT.
273 hipo with 1985 318 pocket ported heads, Holley street dominator intake, Carter afb 4bbl, electronic ignition, and spitfire headers.
I'm not very knowledgeable on cam profiles.
It does have hydraulic lifters.
Good, bad?
Mild, mid?
What can you tell me?
The engine runs great, thanks!
208/212 @050 260 advertised. .440 lift Good low rpm street cam. Mild, good torque will work well with factory converter if automatic and low (numerical) gears.
Should work just fine. If it’s on a tight lobe separation angle, with a stick shift, it can get a little jumpy around take off from a stop. Your notes don’t show LSA so no idea if it is or not.
