dano
Evil Handy Man
So I 'm installing a set of QA1 adjustable on my 69. I understand what their job is and have no binds but....
Install step 4 says "
Cycle the control arm though its full motion to insure there is not any binding in the front mount
or the rod end and adjust the front mount as necessary. Once the front mount is indexed and there is no binding the front mount can be tightened."
OK, well what is "full motion"? The struts range of motion is limited by the washers inside the heim. So where do I set up this now limited full range of motion? Against the bump stop for up and then get what I get for down? Then when I go to install the torsion bar I can't swing the lower control arm all the way down to seat it in. I know others have installed these or similar setups so any thought or inputs are appreciated here.
Index the front mount? OK, it turns and un-indexes itself when you try to tighten it. Jam a screwdriver up their and hope it won't move?
