Installing rear Sway bar
Done Swimmin
Canada
Hi All
I have moved the springs in on my 8 3/4 with an offset package and I need to re-install the rear sway bar. I read somewhere that the bar monuts need to be level when the suspension is loaded. Is that correct?
Level is ideal but the main thing is you don't want it under tension at ride height. That is more an end link thing most of the time.
It's not 100% critical, but it's best to get the ends where the links attach as close to parallel with the ground as you can with the car sitting on the ground.
I prefer the angle of the sway bars arms to be parallel with the leaf springs.
