Installing this cobbled together front sway bar today ...
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Cobbled together sway bar kit
The Hellwig 5906 bar was on my car when I got it.
I thought it was a factory bar at 13/16 diameter, so I ordered bushings
It was the Hellwig bar @1 1/8 diameter, and the bushings for it are hard to find.
I gave Kevin @ Hellwig a call and he comped me a set
They are far superior to others bushings I have seen
The rods that attach to the bar are Energy suspension
The clamps to hold the bar in place I think are PST
The mounting plates, don't remember
Nuts, bolts, washers, can't find them !
Going on today !
I'm hoping to do some small time road racing
My set up
Fresh, as yours is, complete suspension rebuild
With PST 1.03 torsion bars
Offset upper control arm bushings, to gain more caster
16:1 steering ratio box
I hope I don't regret it
This Hellwig 1.125 bar
For now , moderately price 215 60 r 14 upfront and 236 60 r 14 on the rear
I'll use them to get the suspension tuned and the put Nittos and Bilstein shocks on later
I worked on a very unique sway bar a coupla years ago .
Bar was mounted transvere to the upper rad support with the "strut" links going down, - attached to the top of upper control arms .
Racecar .
One of my factory sway bar brackets was bent, I assume from impact with a curb. I replaced both of them with similar brackets to what you have there. this is the best picture I have.
If you are referring to mine, that is the stock bar. I only replaced the brackets and bushings. I thought the picture might help with the orientation of the brackets, as yours look similar.
The brackets on the K frame are Energy Suspension too. I have the same set up on my 70 Dart - has worked well for 20years...
My set up
As you reassembled your front end. Did you tighten lower control arms and uppers with the cars weight? Or suspension hanging in the air? I ask since I'm getting ready to reassemble my dart sports front end. Thank you
No, is it too late to do that, hang the body in the air, loosen them up and retighten ?
It's been 24 hours. Did you get your bar installed on your junk? Or you just talkin about it still? lol
No, I'm still stuck on small, no fun stuff to do. As soon as I get past a lot of the small stuff, I'll do the bar to "reward" myself, I'm actually excited to install the bar, it's definitely something I will feel every second I drive the car
YES loosen them up set the car down on something so that the weight is on the tires and retighten them. If you are using stock style rubber bushings this is very important. This is also true on leaf spring bushings in the back...
I am using all stock rubber replacement bushings.
Hellwig and Kevin are awesome!!!! Did it take more than one ring before they answered the phone?
I can't speak highly enough of that company. It's so rare these days to get good customer support.
