I have an la 360 with magnum heads, and an edelbrock rpm airgap manifold. It is pushing out the gaskets/not clamping tight at the top, using the edelbrock 7277 gaskets. Intake was installed new in March, gaskets replaced in late August and need to be replaced again now. gap at top is large enough to slide a paper into the port itself from the top (or a thin leaf, ask me how I found that out) causing a large vacuum leak. Gasket pushes on both sides, but vacuum leak only on the passenger side as of now. All intake bolts are still tight.
Heads have been milled, however not on the intake side. BUT, wouldn't that cause angle misalignment on the bottom side?
I plan on pulling it apart in the next few days and checking fitment and angles, but what normally causes this sort of issue? Gasket thickness? Everything I've found is problems of a gap at the bottom.
