macdrew77
So i have a 1970 318 with 302 heads and a Edelbrock Performer RPM intake. I was swapping out the valvetrain and decided to pick up the Mopar Intake Gasket Set with the block off plates included. Great. Or so i thought. upon assembly, coolant pours out of the back left side between the head and intake where the coolant passages in the gasket are way oversized (probably should have checked the fit first...) Now this is confusing because all gasket are labeled as 318/340/360. Or is the problem my intake? Can anybody recommend a good gasket they've used with their Edelbrock Performer RPM, maybe also with 302 heads?
