Intake Gaskets....
MassDart
Lifelong Dart fan
Wales, MA
Can I use LA360 intake manifold gaskets on a Magnum that I've put a intake and carb on?
Thanks!
I believe he is only questioning the use of the LA gasket on a magnum..... The only issue is that the LA has a heat cross over and the magnum doesn't>>> Then some LA gaskets can be had blocking the cross over off... gasket angle for the bolt holes might be off a little throwing the ports a little higher... my 2c
