Cuda 1964 FABO Gold Member FABO Gold Member Joined Aug 31, 2020 Messages 145 Reaction score 105 Location Onaway Michigan Aug 24, 2023 #1 Hey everyone just checking which would you recommend using fel pro 1213 or the 1213 S3 for intake gaskets with a eddy air gap and trick flow heads 318 stroker thanks in advance for the advance
Tims 66 Cuda Mopar mid life crisis Joined May 28, 2018 Messages 500 Reaction score 176 Location Poquoson, Va Aug 24, 2023 #2 I used the 1213 gaskets on aluminum heads with a Weiand intake no problems at all. Make sure to seal the corners well Tim
