Intake Manifold Gaskets?
JGC403
Baileyton, TN
I need to order an intake manifold gasket for my 383 build, and I noticed there were a couple options. Is the Mopar Performance valley tray good enough, or should the valley tray be sandwiched in-between 2 intake manifold gaskets on each side? What type of setup is better. I'm using cast iron 906 heads.
I always go steel only with some tacky gasket dressing on both sides for a steel intake. On an aluminum intake or heads I would use the gaskets with tacky stuff on both sides
