matthon
- Joined
- Aug 29, 2008
- Messages
- 3,688
- Reaction score
- 2,733
I have the Weiand high rise manifold pictured below and it is nearly impossible to get the inner 4 bolts tight. I have tried adding different washers, different number of washers, using allen head bolts, different wrenches, u-joint sockets, etc- and nothing works. There is also a limit to the length of bolt that you can get in there, so adding a bunch of washers to bring the head up higher is a no go.
As the bolts get farther in there is no room to get a wrench on them, or an allen socket or wrench, or a regular socket.
The oil is leaking into the heads and fouling the plugs.
I am using the right gaskets, the same ones I used with another intake without issue. There is just no way that I can see to get these bolts tight.
I imagine others have this intake, or a similar high rise, so there must be a solution, or does everyone just stay away from these intakes?
