bizjetmech
Active Member
Putting my 340 in the car. Just discovered that I'm not going to be able to use the Weiand Dual plane I was planning on using.
Engine is a semi-mild hydraulic cammed, 9.5/1 street motor with an automatic, aftermarket street converter, 3.23 gear. Goal is to "look stock, with headers" for the Chevy boyz, but to run "lots better than stock".
So, I'm looking for an intake that's:
-a lot better than the stock, cast iron TQ unit.
-looks/resembles/can pass for the stocker when painted......no "Air Gap" types, or high rises that won't let the stock air cleaner fit under the hood....
-can fit either an Edelbrock carb, or a ThermoQuad/spread bore carb with no adapter/spacer.
-uses the stock throttle cable/kickdown brackets and linkage
-has the "bosses" on the manifold behind the carb, so the stock coil, etc. can be mounted in the stock location.
Back in the day, I had a Holley Street Dominator, which was really a good intake. Wouldn't mind finding one and using it again, but I find it hard to believe that something better hasn't come along in the 30 years since I had one of those.
