CLAY72dart
What is this thing circled in yellow never seen it before and my 72 has a massive vacuum leak from it.
What is that exactly? Never seen one anyways had an aftermarket edelbrock carb.Choke well
Yeah it has a shield over it and i think it is messing up my low idle in first gear at red lights it drops my ammeter and will sputter out if I don’t hold my foot on the gas a little.Choke heat stove. May have a sheet metal insert that rusted out, most were cast in the intake. just make a plate to go over it and seal it off.
I looked it up. I was wondering what that thing from the previous owner wasWhat is that exactly? Never seen one anyways had an aftermarket edelbrock carb.
Should have had something similar to this from the factory. The choke mechanism would sit inside of this.
As asked above, are You just using that Poly intake as a reference? An Eddy intake won't fix whats wrong, unless You've got mis-matched parts that are leaking vacuum etc. If You're pointing out what is actually an EGR base from an LA intake, that CAN be a source of vacuum leakage, but a new EGR gasket is all You need under the block-off to fix it.I will just buy an edelbrock intake.
Take the shield off, and look inside the choke well. Many were solid inside, with no possibility of a leak anywhere. Just used as a heat source for an automatic choke. My bet is you have a vacuum leak from another source. Carb ports, carb base gasket, intake, etc.Yeah it has a shield over it and i think it is messing up my low idle in first gear at red lights it drops my ammeter and will sputter out if I don’t hold my foot on the gas a little.
