65slant
Active Member
Hi all
i am installing a vacuum gauge into my 65 slant with a carter bbs so i don't have any extra vacuum ports on the carb. i just have one for the distributor witch doesnt work because it only gets vacuum when the throttle plate is open. the carb is from a 63 so there are no provisions for the PCV. so do you guys know what the size of the plug is on the rear portion of the manifold so that i can take it out and put a compression/plug fitting on the back? I think the plug was used for power brakes later on, thanks
