Jbcuda
Active Member
I’m trying to remove the trunk wiring from my 68 barracuda fastback, wondering how to remove the side lights in the rear seat area, to access the wires for them,thanks in advance.
It’s a fastback the lights are head high on each side in th back seatAre the rear seats out?
If it is the glass dome type courticy lights you are talking about. At least on 67 dart convert the glass dome uses friction spring fingers and you can pull it out from inside the car. Plastic prybar trim molding removal tool would work well
Thank you, for your response.Twist off the bezel counterclockwise. Be very ginger with the lamp, the old factory clip in, plastic holder will be extremely brittle.
