When I was having issues I wired up two LEDs under the dash. One went to the power side of the ballast resistor and one went to the plus side of the coil. I could watch them when I was having a no start to see if I had power. That way I could tell where I was losing power.
They never went out so I learned that power to the coil wasn’t my issue.
Then I hooked up a handheld meter with a frequency counter on it. I hooked it to the negative side of the coil. When the car was running it would show a frequency. Forgot what it was, maybe 5KHz. When the car cut out, there was no reading on the meter. Then I knew it was the ECU or the distributor pickup. Replaced the pickup. No change. Changed the ECU. That fixed it,
