Intermittent shift problems
Tuckerjr
Georgia
My 904 transmission sometimes does'nt want to shift from first to second gear when in drive.
When it sticks going from first to second, I can shift from drive to neutral and then back to drive and it will shift fine until the next time it's parked. After that it may or may not shift correctly the next time I drive it.
Is this a linkage issue, or do I have a valve or something sticking?
Sounds like a sticking governor. With that being said theres usually a reason for it and thats metal contamination. Removing the pan should confirm if thats your problem. Also remove the filter and look on top of it for small bits of rubber as well.If either or both are evident an overhaul may be your next option.
