[SOLD] Iron Case A833 OD new synchros
MidnightSwinger
Woodland CA
I had this posted once before, someone bought the shifter, now I’m reposting just the trans itself.
Iron case with build date of 5031 which is Wednesday, May 7, 1975. 727 output. Strongest stock option for overdrive 4 speed.
The trans was rebuilt with new syncros, and resealed. I ripped the gasket when removing the side cover, so it will need a new side cover gasket.
Includes the hurst shifter mount. I tried to remove it to sell with the shifter and the top two hex bolts won’t budge. One of them has a piece of broken hex stuck in the bolt head. But it doesn’t hurt the functionality whatsoever. Bolt a shifter on and forget about it.
$325 located in Lacey WA 98503. I will box/crate but please understand shipping will be over $150 and close to $200 if you are east coast. Please don’t ask me to crate the transmission and then change your mind when you see the shipping cost.
