is 727 lock up converter same as A518 converter?
maca
australia
Hey all
I have a a518 lock up converter I would like to use in my 727.
My 727 is a lock up box too and they look identical. Even input shafts etc are identical. Are they interchangeable
Hey all
There is a 3 digit code stamped on the body of the A518 converter. If you can post that, I'll let you know more about it. They may or may not be the same.
Thanks for the reply guys. I have put it in the car now so unfortunately I can't read the numbers. I measured the shaft coming out of the boxes and they looked identical. Hopefully it will be ok.
