I know Haynes isn't the best way to go, but here's what I have:
'71 Demon instrument cluster wiring:
Haynes states:
Is it as easy as attaching the sender side of the gauges to the correct circuit (for instance, attaching the dark blue wire to the back of the sender terminal on the aftermarket gauge?), or is there something I'm missing?
Also, since the oil pressure sender and fuel sender are on the same circuit, would it be okay to attach them both to the dark blue wire?
And finally, I have no idea where on the transmission (904) the speedometer sensor is, nor do I have any idea where the oil pressure adapter (huge oil-filter-looking thing) goes. Any ideas? Thanks for all the help.
![DSCN1506.jpg](http://i7.photobucket.com/albums/y251/sharpie1k/DSCN1506.jpg)
Haynes states:
![DSCN2546.jpg](http://i7.photobucket.com/albums/y251/sharpie1k/DSCN2546.jpg)
