Is this a slant six k frame
nwdart
friday harbor
71 dart project I picked up last year, finally made it inside the shop for first time today. Pulled a 85 318 out of it this morning with one motor mount bent in to fit. I already have Schumacher 6 to 360 magnum mounts for my 360/380 magnum. Both of rubber mounts are same thickness on k frame . One Schumacher mount is 5/8 thicker. Thanks. Nwdart.
i have a 73 duster that I'm doing the /6 to 383 shumacher mounts on, can you take a better pic of the mounts id be able to tell better, also, i read that if its a 318 it used a /6 k frame as well, for some reason i want to say they can use sb or bb mounts. but this one is most likely /6 hope i could help good luck.
i believe it is 22 inches from motor mount perch to perch on a slant 6 k member (my 72 duster was a slant 6 originally with a 318 transplanted in it too lol)
Thanks guys slant six it is, the rubber mounts were different than the shoemacher mounts I have had on the shelf for ever and it thru me off. Decided to go a different route and use my hemi deny k frame for now until the 69 is ready,which will be next winter at best. At that point will probably put the 6 Kframe back in all rebuilt. Started a thread on the 71 dart. Thanks again nwdart
