Is this ok to use
straightlinespeed
Sometimes I pretend to be normal
Uvita, Costa Rica
should be fine, Its the steering shaft you need to worry about. Pull it out and make sure the shear pin is OK. Also you dint need the entire column to convert to floor shift. You only need the collar up top. It should swap right to your original column.
This is my original column that I was going to use. The rest of the column is fine, it was just this piece that got damaged. That is why I was concerned. Im not sure if this causes an integrity issues and the column will flex or what not.
It was already dented there from the factory for the collapsing function, it just scraped up a little.
It's fine.
