Is this the kickdown Linkage I need for Big Block swap
That looks like but ouch on the price. I bought the kickdown cable kit from Bouchillon for less and it works great
Here is mine set up
And it clears my dropped base filter bottom for carb to hood clearance
At a swap meet. There are 2 different openings between Holley and Carter carbs. I think this is a 3" drop with a 14x3 filter. I was thinking of going 2" just to see if it was any better.
Put up a wanted add and I bet you'd find The pieces you need a lot cheaper. Hell, if you got a hold of a BB throttle bracket and SB kickdown levers, you could get by with a little cutting and welding.
