"It aint redneck if it works"
diymirage
HP@idle > hondaHP@redline
michigan
Background story:
I got a little 4500 gallon pool for the kids
Since we live in Michigan, it doesn't seem to get past 70 and I tried a few different ways to heat it
I have a "solar cover" on
Might so more to prevent heat loss then to actually aid in heating it up
At some point I bought a "heat pump"
Ran that for 3 days straight, no difference
Finally, I came across some guy selling a heat exchanges for a torpedo heater
I figured, why not ?
I put the whole thing together this morning (pool temp being 69.3f)
Fired her up and measured the outcoming water
What would be wrong with a water bed heater?
My guess is the capacity
I've never owned a water bed but I can't imagine it's more then a few hundred gallons
So it would be like trying to use a hot tub heater, there is just too much water there (this pool is 9x18x4)
I think I'd spin your heater around 90* to keep it from warping your pool.
There's that, plus I don't know that I would want that warm exhaust air blowing at me.
I could do the math (maybe), as there's two heat exchanges going on here (air to air, and air to water), but like Derek on VGG says, "If it works, it is really a dumb idea?"
Thats awesome, it used to cost me 180 in propane to heat my pool one time. I like the BFH laying there, must of been fun.
Grew up using those torpedoes to warm the shop, or start diesel engines in ND winter weather, but never saw a water heater attachment like that. I say awesome idea, and a ton cheaper than any other heater out there for a pool.
And as said above, I would face the exhaust air away from the pool......
I'm guessing you run it and shut it off, or is it continuesly running while you are using the pool? I'd think it would hold the temp for a long enough period to swing without having it on, after it got to temp.
@RustyRatRod I know the heater for my old hot tub, approximately 900 gallons, took a whole day to heat up to temp (103), and still only hit diy's temp after about 20 hours. I'd think that a water bed heater would never get do a thing you'd notice on a pool this size.
My ex wife rented a hot tub for my 40th birthday, one of those small 7 or 8 ft diameter soft sided ones. She filled it with cold water and wondered why it didn't get warm. :BangHead:
I drained it and refilled it with hot water, amazing what a difference that made!
one of the fittings was a press fit
it ran for about 3 hours this morning and got the pool up to 80 degrees, so the idea is to run it before the kids want to be in, and then let it be the rest of the day
since today is the first day im using it, its running while they swim, because it gives them a hot jet
If the exchanger is aluminum finned? it`s a wonder it ain`t melted yet.
im not sure
i know the lines are copper
Ok, that was funny right there!
:lol:
N
Put the pool in your new pole barn and swim all winter!!
That would be awesome
After looking into thing, I will most likely use the pole barn budget to put up a small carport, and use the rest to pay off debt
Then in a few years, I should be able to build a barn that's big enough to have a second story
