How did you supercharge your /6 with a a gm supercharger.
sorry this took so long to reply,
First off i dont know alot about blowers but i thought it would be fun to try it and i work in an environment that i have access to alot of matal works and hardware,
First i took the carb off and cut the opening in the intake as big as i could.then i made an adapter plate that was 1.3/4 thick to bolt from the intake to the blower.then once i got that situated on the motor i changed all the pullys to a serpintine belt,i got the pullys off of a 98 ford torus and believe it or not they bolted right on.
I had to machine a spacer for the crank pully.now for the carburator,i took the throttle body off of the super charger and made a 90 degree adapter for the original 2 barral carp to bolt on . Other than that it was just a few mods on the thottle linkage and kick down.
Alot of work but the result of an over driven eaton m 90 sounds awsome and gives a pretty good power boost. I took it to the local track on a test and tune day and ran a 14 flat
If u ar thinken about doing this,dont get in a hurry because it takes time.
http://www.projectplato.com/cars/bigredhome.html
I have had a discussion with Al T on this from /6 forum. I have a superchaarge and everything but I have yet to find anyone who will convert my intake for me so my project is dead but I sure would like to do this with my 62 wagon. So if anyone can help out with the intake please let me know.
