JR Dragster for sale $4000 "turn key"
M347
Active Member
Ohio
Rating - 0%
0   0   0
Jr Dragster for sale. It is a moly car with rack and pinion steering. It was built in 1999/2000. Has new helmet bars, leg net, and adjustable pedals. It also had new kidney bars put in by Mike Bos at Eastern Conference Finals. It has a new fuel cell, new flip dial board, and new crank supports on both sides. Car is narrow on the back, but has a longer axle to move the wheels out wider for a new driver. Motor is a .174 over Blockzilla with a 33 mm carb and a Polar clutch. Oil changed after every race. Rear wheels are powder coated black, and the front twisted fire wheels and tires where also new at the start of this year. Will fit up to 5'3"-5'5" driver. Car weighs 240 race ready and runs 9.90-10.10 deep staging at 440-450lbs. Ran 9.30's with 130lb driver. Should go 8.90 with small driver. Car won the last race we took it to on Sept. 27th. Will include the tow dolly with the car. Paypal add 3%. New car here so this one needs to go. Located in southwest Ohio. I will also include a dual bearing briggs block with everthing but a carb and header if you want to build a 12.90 motor to slow the car down.
$3800 obo. Might take 499-512 inch short block in trade.
Tracks are starting to open up. Race ready car and tow dolly. Car needs harness replaced or recert. Add fuel and child and go racing. $3500.
