its hard to think of air as a solid bcoz its hardly seen .......and in the conventional way of thinking, a solid is something visable. yet its visable inside a container such as a tire ....you can see an over inflated tire
so that being said is it possible that an object that is set in motion is kept in motion by a transfered force of another solid which is actually AIR. and as the air dissapates and friction overcomes the kinetic motion and the car comes to a stop.
so if it has been proven that an aero dynamic car like a superbird is able to cut though the "solid" air and reduce friction is able to go faster.....wouldnt it make sense that a car that is aero dynamic on the rear side would stop better, if you think in terms of car with the brakes applied at a complete and the air from its peak speed is still in kinetic form and still pushing the car.
so with that ...how would we measure the pounds per square inch of of air on the surface of a car going full speed?
is it possible that all air in the atmoshpere is compressed air and that may be the reason there is no air on the moon bcoz of the lack of an atmosphere that is effective in compressing the air.
if what i am thinking is true then that would undermind newtons law of motion......and in a way that would not surprise bcoz he is working on a theory only and there is no way to test the theory either on an astro or quantum level.....the only test available as of now is within the confines of the atmosphere which may compressed. so where do we set the benchmark the theory to account for the compression of the atmosphere.
so it would make sense to me that we are approaching auto design wrong and the awnser is a vented and aerodynamic apporach to better braking effectivness.
i dont know ....just a thought.....any physics guys here?
