K frame and A arms 67-72 73 and up
Duster Drag Car
connecticut
67-72 K frame $250.00 73-76 Disk brake upper and lower control arms$200.00
a 73 and up k-frame would fit your 67. the k-frame you pictured is a 67, a one year only by virtue of the idler arm mount. the control arms? maybe early or late disc, would have to check the stud diameter of the UCA.
thank you yes I know the 67 K frame and idler arm are one year only, so the control arms your no sure of, I think this set up was on the car before it was switch, to QA1 tubular K frame and control arms just don't to miss inform anyone I sell them to.
Can you post pics of the bottom of the K frame and the top of the upper arms?
