K-Frame Application in A-bodies
Mike337
Cannelton, IN
Pulled a K-Frame from a 67 Formula S 383 car. What other year Barracuda's will the K-Frame fit? Will it fit Darts also?
Mike
Yup, and Yup. It's all the same 67-76. Though the 73+ spool mount type is superior.
67 also has a hanging mount for the idler arm, not the cup/socket style on 68 up K frames.
...the 67 idler arm is much more expensive, and if damaged, it tends to mess up the socket in the K-frame, which is not really repairable, other than in the sense that you can fix anything if you have enough money.
Hi MobileCustoms
I think there was a section in the Mopar Chassis manual on changing the idle arm mount on a 67 to the 68 & up style. If it's not in there then it was a mag article at one time. The basic idea is to just cut off the 67 and weld on the 68 & up style, or a simple addition of the other support bracket for the 68 & up. carful measure and fabrication of course. Has been done...if you look at the two K frames its easy to see how.
