[WANTED] K frame bolts
If i wasn't in the hospital right now i could fix you up with 4 of them that i had sent out and had refinished to the OEM black phosphate.
Don
I have them if still needed
u guys know u can get allen head bolts at fastenall that will work and be as strong , or stronger for cheap , unless u just gotta have stock bolts .
yeah, i would have gone that route but my local one is closed due to this virus. so is tractor supply, my only other local bolt option. so i figured if im gonna order any, i'd rather order factory ones and give the money directly to a member here than some big chain.
You can get allen heads with the larger shoulder that properly locates the K-frame like the factory ones??
