K frame ID needed
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
I have a K frame I need to figure out what it is, Is there a part # on it somewhere?Under the rust!
If you can post pictures, @Jim Lusk is the MAN. He'll help you out. he might can tell you how to ID it without pictures, I don't know.
Post a picture, only way to know unless it has a coin welded to the front of it.
Yes I would consider selling it.
I have the LCAs and the sway bar and motor mount with it.
Actually I also have the steering gear and all the steering out to and including the spindles and I believe the disc brakes. I do not have the UCAs
I took this all apart. I will have to gather all the pieces and clean and inspect and see what condition they are in.
