The K frame is the name given to the K shaped saddle that the motor bolts into. I'm sure your car has one unless there is no front suspension under it whatsoever as some of the front suspension parts also bolt to it. FYI, nowadays there is no need to change the K frame to swap engines as Schumacher sells just about every possible engine mount for all the different K frames. Good luck with your project, Geof
