K member question
http://www.engine-swaps.com/ they have a chart and pics so you can look and be 100% sure. you have use the pull down menu on the left and they have a k-fram identification section. but they should be the same as long as 1 wasnt a slant6 and the other a v8
some where along the line there is a difference in the idler arm mount . i believe the motor mounts are the same.
67 stands alone in the idler are mounting. 68 thru 72 are the same.
I'd be careful about these pictures!! I think Mike has a great site and a wealth of information, but he is focused on the engine mount brackets and not the rest of the K-frame. As an example, his picture of a 66-67 hemi K-frame is correct in the engine mount area, but it is a picture of a 68 K-frame (the idler arm has the double sided mount, 66-67 used the single side mount on B-bodies!).
I do know the 67 Idler arm is a 1-year only item on A-bodies, but is the k-frame diffecrent? not sure???
