If the calculations are correct and you want to run pump gas, you will need a decent size cam to bleed of some compression off. If you have a cam in mind, i might be able to run the specs and get a dynamic compression number for you. I personally like a max of 8.0 to 8.25 so you can still run a aggresive timing curve. Just my opinion.
