GMachineDartGT
Senior Member
Keisler A41 Automatic Overdrive transmission kit for A body mopar small block. This is a stage 1 model rated for 450 ft/lbs tq. This was used in a customers car for less than a year. Never abused or raced, customer changed build plans for the project. This kit includes the following parts:
Keisler Modified 4L60E Transmission For A Body Mopar With Small Block (Same as Gen 3 Hemi). Accepts Mechanical or Electrical Speedometer.
Keisler Specific Transmission Crossmember
2200 RPM Converter
Keisler Wiring Harness and Controller. Includes data cable for programming.
Throttle Valve Cable
Flexplate
Converter to Flexplate Hardware
Dust Shield
Transmission Mount
Dipstick and Tube
B&M Ratchet Shifter, Cover and Cable
Starter Support
Starter Spacer
$1000
Located in 11746. Local Pick Up Available
Custom Crating and Worldwide Shipping Available
2200 RPM Converter
Flexplate
Dust Shield
Transmission Mount
Dipstick and Tube
Starter Support
Starter Spacer
$1000
