66samsmith
kelsey-Hayes 1965-1972 disc brakes set-up all completely redone. Everything has been cleaned painted with etching primer and topcoated
with a high temperature rust resistant cast iron paint.
Rotors are new with new right hand thread studs, bearings and seals. The
bearing have not been packed with grease as I thought some people might want to do it themselves. If you prefer I can do it before I ship them.
Calipers are remanfactured with stainless steel pistons from "Calipers on
Line." ( $110.00 +shipping each ) The line from the caliper to the brake line is not stainless.
Splash shields have some dings but are very straight.
I have a proportioning valve and new stainless power brake lines from the valve to the master cylinder available for an extra $70.00. ( No master cyclinder included. I usually use a 67 dart cylinder from Advance Auto Parts for my early 63-66 "A" bodies.)
Sell does NOT include lower ball joints as they are available from O'Reillys
and others. Bolts are grade "8" also available at any good hardware store.
Also does NOT include brake lines. (does include caliper hose brackets
both L&R).
Price is $550 plus what it costs to ship. I can assemble everthing including
packing the bearings but it will probably be cheaper to keep seperate so that I can use more boxes. Your choice.
both L&R).
