Kelsey Hayes brake Rotors
71duster06
West Michigan (GR)
Hello. I am in the process of switching over to the KH disc brakes. the rotors that came with the parts are shot and i need to replace them. Will i need to re-use the hub since most of the rotors that i found were just the disc without the hub. I anyone could give me a hand here that would be awsome. If there is a place that sells both the hub and disc let me know. Thanks
You will have to reuse your hubs, I haven`t seen new replacements anywhere. Summit Racing carries the rotors too.
What he said, I may be wrong but KH only made the calipers. I'm using the same thing and thy are great. I just came from a dui talk to u longgone
Hubs are available new, I'll look for the link I have stored -somewhere-LOL!
There was a thread either on this site or on Moparts, about 1 - 1.5 years ago with the hub availability info.
I found the vendor that manufactures new hats/hubs --- see link below:
Contact the vendor for more info.
http://www.durabrake.com/
Now that`s worth saving.
I talked to them and they said they dont make car hubs, just rotors for certain years. Thanks tho
Once in awhile a NOS hub/rotor combo shows up on eBag. I've managed to snag a couple of them - both with RH lugs at pretty reasonable prices ($100 - 125 each)
They (Durabrake) were selling the new hubs in 2007. Wonder what happened.
Try Moparts website for SBP hub sources as well. They are out there.
Jim Lusk, a regular on that site, is a great source of SBP K-H disc brake parts sources.
