If you look at the grove next to where the key is cut you will see it is wider. The area between that grove and the actual cut is narrower. Now if I have this correct "B" is the second series in the locks/keys. The "B" key will insert in earlier locks but the plain(Y) key won't insert in the later locks. This extra key may not belong to this car at all.
