Dusterdude72
IN MOPAR MUSCLE MAGAZINE
ok so awhile back I installed my trans and my B&M pro ratchet shifter.
while I was down there I removed my kick down bracket from the trans because I figured since I didn't have any of my kick down linkage anyhow ....I would just manually drop down a gear by hand with my shifter rather than doing so by mashing the gas.
( I have done this on many vehicles before but mostly GM and I think a few fords) and I had never had any problems with it.
however I was recently told here on fabo that doing this on a mopar is different and that it will burn my tranny up because the kick down on the TF trannys controls line pressure and so on.
I just wanted to get a few more opinions from others and make sure rather or not this is the case?
and why exactly this is the case in technical terms?
also......if this is the case.......where can I find the parts I need to run a kick down? all I currently have is the bracket itself that mounts to the kick down shaft on the transmission.
thank you in advance everyone.
