[FOR SALE] Kick panels with speaker pods for 63-66 A's
66Dvert
Working on my custom car parts again!
Webster , florida
got some more speaker kick panels ready to go $134.99 on ebay
1963-66 Dart,Valiant and 64-66 Barracuda molded Kick panels with speaker pods | eBay
These look great. Would you consider to do another Mopar, if it’s even considered a Mopar. I am part of a Jeep club, TJ’s especially, 97-06…if you didn’t know. On several occasions people have said, including me, that they would like a 6X9 pod on the sound bar instead of the 6 1/2’s. Is this something you could do, if so, how much? I could send you a pod to work off of if need be.
Thanks,
A
Thanks,
A
I probably could if I have the original part to design from and some good pictures of what and where it goes on a TJ jeep I'm doing 61-3 lincoln setups and 65.5-6 mustang pods (those are exclusive to a company though and I can't sell the mustang ones)for a customer now. so a few more designs won't hurt. Private Message(start a conversation) me your contact info on this and I'll see what I can come up with and cost wise would be about the same as the ones I"m making now depending on material sizes
What is the max depth of speaker that can be used with these?
It's lowest is 2.65 and highest point is 2 .9 plus the thickness of the plastic I used to form the part, the cone is slightly tilted to clear the dimmer and direct the magnet into the lowest part of the sidepanel . I use Fosgate speakers in my car and they have a 2.875 depth fron the magnet bottom to the bottom of the flange that goes on top of the plastic and they do not hit the side panel,convertible wiring has to be pushed down about 1/2 inch depending on where the relay was mounted, some dimmer switches have to be moved inwards also
