usdart
A little expertise needed please.
I have an Eddie intake and carb on my 318/ 904.
The throttle cable is worked out, The kickdown rod I am using has an adjustable threaded end on it where the slide connects to the carb.
Questions are.. with the engine off and all at rest should the kickdown be all the way forward? Then at full throttle be pulled all the way back?
Or do I just need to experiment?
I would like a starting place to adjust from there.
