dkbug
Looking to install a B&M shifter into my car this weekend. Now to do so, I will need a few things to reference off of. Where exactly did you guys mount the shifter at on the transmission tunnel? Also, how did you route the shift cable from the shifter to the shift linkage on the transmission?
Anyone have a picture of how the kick down cable mounts to the transmission along with how the shift cable mounts as well?
This will be the first time I install either one of these and seeing as how I am younger than some of you more experienced members, I will need a bit of info on adjustment for both pieces.
Thanks in advance,
Dakota
Thanks in advance,
Dakota
