Kickdown Carb Rod
One angle
For sure the Holley bracket is needed and you may have to raise the manifold bracket to allow for the extra height caused by the Air Gap. We run the same setup on my brother in laws car and in fact, one of the images in my book is it.
Here is the four barrel lever and the two barrel lever and the only rods I have left
Hmm, interesting.
May be the same kind of rod. We modified a 2 barrel one to work with the 340 bracket and the other two barrel parts we had.
Please check that bottom lever to be sure it is the short one. The long one will cause you lots of issues unless you redrill it.
