Kinda a moronic question....
Huntsville, AL
Ya, I am sorry for this question before I ask it, still learning.
I have already thrown my old rear end out of my 72 scamp, and I am about to order a moser 60 package probably on friday, only thing is, it asks for my stud type. I am going to be running willwood brakes, not exactly sure on the rim/tire combo.
Any way somebody could give me a hand with this?
Thanks a ton.
is it asking for size or asking if you want pressed in or screw in ?
1/2" definately
Stud length is determined by axle hub thickness (you can ask them this) and the thickness of your rims at the point where the lugs attach. This measurement is critical if your running mags with acorn nuts. If your just running steeles and using regular nut it doesn't really mater as long as the lugs protrude beyond the nuts. If the lugs stick out 1" or 2" past the lug nuts it doesn't matter.
Always ask the rim manufacturer how long the lugs should protrude beyond the hub face then add the hub thickness to the dimension to decide on the lug length.
By the way, it's really not difficult to change them later.
