[WANTED] L/R 69 fastback inner quarter panel B pillar to trunk
jimharvard
JimHarvard
Pittsburgh, Pennsylvania
i need the passenger AND driver's side inner quarter panels for a 69 fastback. i need the COMPLETE inner panel that goes from the B pillar (door lock area) back to the trunk area. this panel includes the window crank mechanism area back across the inner wheel well TO INCLUDE the vertical support panel that goes from the back window down to the trunk floor.
i'm doing a OEM restoration on a 69 fastback so the panels need to be removed by separating them at the spot weld area leaving the spot weld metal area intack.
if you just want to "cut off" these panels from a donor car that would work also so long as you cut the panels off ABOVE the spot weld areas - and that has to be around the ENTIRE panel - roof area, floor area, rocker panel area, trunk area.
if you have a car that has these panels, please email me at jimharvard@aol.com or here at FABO on the PM message link.
These for the 440 Cuda?
yes they are. it's the M-code that i have down at AMD right now. they thought they had located a set from stephens performance down in georgia (?). ted stephens sent me an email yesterday saying they were having a problem with the ones they thought they had. he did find a set but the lot wants and unreasonable amount of money for them. so i'm going to see if i can find another set from someone. and of course, you can "usually" find "anything" here on FABO.
AMS obsolete in Fairmont, Ga. Has several FB's on the lot. Mike likely wants big$ but worth a shot. Maybe that is who Stevens talked to.
i have a complete 68 fastback in my garage that i bought as a parts car. however, i really didn't want to start cutting that up. i could probablyl sell it to someone as it's pretty much all there. i bought it because it has original OEM discs on the front, an original "wood" ralley steering wheel and a bunch of interior parts.
I would not try to save it after close inspection but it still has some decent metal, at least what you need!
By the way, I pirated a few pieces off that car for my restoration a couple years back. He has at least 2, 69 and probably 3-4 67/68 FB's on the lot.
The one pictured was white with saddle interior.
Contact numbers if you need them. His yard is about 50 miles from AMD'S shop in Cleveland.
Mobile 706-337-4606
Shop 770-608-6003
Mobile 706-337-4606
Shop 770-608-6003
i sent my parts request and info to ABS along with the above picture here in my post. hopefully i'll hear from them in a few days.
do you know mike? if you do, i'll mention that i got his info from you - who knows, maybe that will get me a "deal?"
He is the former Mitchell Motor Parts.
Lots of folks have some strong opinions of the Former "Frank Mitchell".
Mike is a decent fellow but I think he bought the lot from Mitchell with stars in his eyes! He has a "large" warehouse full of NOS stuff there and also repops lots of pieces that hit the market. He usually commands some big bucks for the NOS stuff. IMO most of the parts in his warehouse are out of any kind of order and need to be throughly catalogued and binned in a mannerly order. I offered to help organize it all for some discounts and fun in my spare time but he was not interested. If you see stuff on e-bay where the seller is FMPARTS or something close that is Mike.
