Woosley
Active Member
-360 J heads= These things had a mediocre port job somewhere down the line, but do have 2.02/1.6 valves. They have no visable damage or cracks $600
-Stock stroke cast Mopar 360 Crank= Had etchings indicating .010 turning, and that's all the exact details I know. Has no noticeable or obvious grooves or wear= $150
-1976 360 block and mains= .030 bore. Cylinders still have visible hone marks. Shows no obvious damage or wear, and should be a good stroker candidate=$300
All parts located in Boston, KY. Prefer pick up.
