67dodgedartconv
What goes over this opening? This is the drivers side of an LA 360 intake with 360 heads on a 318 block replacing a 67 273. Have no idea what this is or what to do with it. Do I need some kind of block off plate?
No EGR required here. Thanks guys, will make a plate.Yep block it off if you are not using EGR.
Ok, may look into this as it is a mild build. Thanks.If it;s a mild engine an EGR valve can actually improve MPG by a couple of points. There are some benefits.
